Toto drake refilling problem
kevin 71
I purchased 2 new toto drake toilets for my home (have been using for approx 6-8 months). Both do a great job but i have recently began to have problems with each toilet taking 1-4 minutes after flushing the toilet for the tank to begin to refill with water. Is this a common problem and how can i fix it? Any answers would help. Thanks!!!
If it's the Korky style fill valve, they can be cleaned by removing the cap.
Korky Style instructions
It's best to just replace the $2.49 part though.
They also use two other styles, for those I would contact Toto.
theplumber
CA
Sediment could also get stuck back in the anglestop or between the flex connection into the ballcock. You can disconnect and try running the flex connector into a bucket to make sure your problem isn't in the wall. Don't forget to shut off the anglestop before you disconnect the supply line. :)
kevin 71
still problems with toto's
Cleaned both valves (they are korky style) and still having same problem. Any other suggestions?
Kevin
Probedude
California
Can you tell if the float in the Korky is not dropping down after the flush? Or is it indeed dropping down but still the tank isn't filling?
The float uncovers a port on the top of the Korky valve, this allows the diaphragm inside the cap to actuate. If that port is blocked with crud, that would cause the problem you're seeing.
