RonnyK
Hi,
I just installed my new Carrollton toilet (love the look) and wanted to run a few things by those in the know here.
Flushing -- The flapper appears well-adjusted based upon the length of the chain, but a simple flip of the flush lever doesn't cause the entire (or most of the) water in the tank to exit. If you hold the lever down, of course, you can get a "full tank flush." Is this by design?
Filling -- How long should the GMax fill valve take to fill the tank? Mine arrived clogged with debris. I know because I flushed my water line before connecting. Disassembling and cleaning seems to have rectified the problem (i.e. it now fills) but it seems somewhat slow. 16 seconds to refill from a quick flush; 40 seconds or so to fill the empty tank.
Thanks,
Ronny K.
Thanks,
Ronny K.
