Plugdup
This has been going on for 35 years. Sure I’ve lived with it but would like to solve it.
Got 2 toilets not back to back - maybe 20’ apart on a straight line. Both vented to a common vent system; there is ony one pipe through the roof. One of them looses water such that the internal trap gets emptied or at least partially emptied letting fumes into the house. This does not happen all the time. It can be years between events and an event might continue for up to several months. Just some times and the rate of loss varies. Only the one toilet and not the other; never the other.
First reaction will be that it leaks; but! When away for vacation I would remove the toilet from the pipe, stand it in the shower, cover the bowl with plastic wrap so the water could not evaporate and after 2 weeks the water had not drained. Not a fraction.
My only thought is that the wind over the vent pipe opening creates low pressure thereby sucking the water out of that toilet. But why not both toilets? And if that is so why would it continue to suck water out after the trap is partly emptied? Probably wouldn’t. I suppose it might suck out just enough that the trap is ineffective but still has some water in it. Not only that it happens with or w/o wind. Scratch that theory.
Sewer fumes have gotten into the house but maybe less than would be if the trap was fully emptied. The fumes have been smelled for sure. I have not swapped the toilets nor tried a different one.
I cannot relate this to wind or heat or cold or temperature or weather or time of year.
