I'm installing the plumbing (DIY) in our small cottage in Maine. I'm a bit confused as to what I'm allowed to do with the venting. All plumbing is on the first floor and there is a full basement. The toilet flange is 8' from the vertical vent. My main waste pipe is to be 3" PVC as 4" is just too big for 1 bath and a kitchen sink - all low-flow. I understand that the max distance to vent is 6' with 3" waste; 10' with 4". I have the altitude to run a horizontal vent from the 6' point, pitched 1/4" to join the vent just above the waste line. Is that acceptable, or does the fact that the vertical vent is 8' away kill the deal?
Other info:
Shower drain is 2' from vent.
Lav is 7' from vent and will have an AAV (inspector allowed)
Kitchen is 6' downstream and will also have an AAV.
Venting is difficult to handle as its timber frame with SIPs and an open plan with only the bathroom partitioned off (wife insisted.)
So, before I ask the inspector - can I do the above? If not options?
Thanks
Bemis
Other info:
Thanks
Bemis
