canadave
Hi,
The two-piece American Standard toilet in our new (to us) home is relatively new, but seems to flush relatively weakly. When I depress the handle, water fills the bowl to raise the water level, swirls around for a few seconds, then descends and empties the bowl; however, sometimes solids or the odd piece of toilet paper will remain behind. A second flush usually gets it down; rarely, a third flush is needed. Note that the flush seems normal to my eye--it's not like I look at it and go, "wow, this really doesn't seem to be flushing right." This is on the upper level of a bungalow; the toilet on the lower level of the bungalow is fine.
The house is newly renovated and water pressure isn't an issue. I've snaked the toilet, and there's nothing apparently blocking it. Also used plunger just in case--nothing. The water level in the tank is about a millimeter above the marked water level indicator. Due to various minor issues/leaks, so I've replaced just about everything inside it (flush valve, flapper, etc) with good-quality equipment--it's rock-solid now, but still has this flush issue I'm describing.
I've used other toilets (maybe Kohler, I think?) where the water just dives straight down in one quick "gulp" when flushing and doesn't even seem to use much water to flush; it doesn't rise into the bowl and swirl around before going down, like mine does. Is there a particular "type" of toilet this is, if I want to buy a replacement toilet? I like these more, as they're also quieter.
Also, is there any ideas anyone might have for further troubleshooting of my toilet?
