Daffypuck
Ive search all over and cant find a specific mention of this problem. After I flush, as the toilet is refilling, it fills, then stops, fills, then stops until it is full again. The bowl level varies from low to full after flushing. Instead of a steady filling sound of the water, its as if the water is being turned on and off several times as it fills. I also have an irregular flush pattern as the water is exiting the bowl. Instead of a smooth circular flush, it splashes back and forth like the the toilet is being slung back and forth. Any ideas?
