Seymour Ovitt
Greetings. First post. I have searched for an answer, but have had no luck. Maybe I am using the wrong terminology.
If anyone is familiar with plumbing in New Orleans, you will understand my dilemma. Many of the older homes have a detached garage behind the house, near the rear of the property. It was common to have the water heater, and the washing machine (and dryer if you could afford one), in the garage.
I recently purchased a home that was originally set up that way. The owner before me, put the water heater inside the house, and converted a closet in the hall into a laundry room, tore down the garage and had a new slab poured for a new, larger garage. He also stubbed out the back corner for a toilet. I shoved a garden hose down the 4" drain, and let it run for 30 minutes. No back-ups, clogs, or apparent leaks (looking in the yard, later, for damp/wet spots). There is a vent stack back there, too. I want to put a toilet back there, however the run from the toilet to the street is well over 90 feet.
I am no plumber, but I find it hard to believe that these new toilets with such a small amount of water per flush will be able to carry any waste all the way out to the street. Aside from telling anyone who uses the toilet for something other than a whizz to flush 2 or 3 times, what are my options?
