I have a basement bathroom that I have decided to finish. The rough in has a 3 inch pipe sticking up for the toilet. (pic below) I was curious the proper way to install the flange? I will cut the pipe off flush with the concrete. I have tile already installed around the pipe as you can see in the picture. I have 2 options 1.) install the brass flange by just tap conning it to the floor and then set the wax ring and toilet or 2.) Install the glue in style flange and then tap con that one down. I am confused if I use the glue in style or just the brass style? Is one way proper or another? Thanks in advance for any and all help
