Mark Garrenton
The contractor poured my concrete shop floor without placing foam around the toilet 3" pvc drain pipe. I had to drill and chip to get clearance for toilet flange to slip over. The pvc pipe suffered some gouging in the process. In a moment of stupidity I cut that pipe a bit short. The flange lip engages a out 5/8" to 3/4" with the pipe. I placed a short piece of 3" pipe into the flange to take up space. The pieces were primed and a heavy coat of solvent applied before seating the flange. I then used more solvent, 2 or 3 times, around the inside of the joint to fill any gaps. The flange was secured using 1/4"-1 3/4" tapcon screws. Does anyone see an issue with this install?
