BritGarnell
Hi Everyone!
Hope you are all well and had a good holiday! We have an issue that occurred over the holiday that I “think” I might be on to but all and any guidance would be super appreciated!
So long story short, we had a new bathroom added where there was not one before on our top (second) floor. The stack for that new bathroom runs straight down the house, turns horizontally in the basement, and then joins original main stack in the basement. I know for a fact that the new stack does not penetrate the roof - they just used an AAV.
We didn’t know we had any issue until we’ve had family staying for the holidays and using the spare bedroom and bathroom down in the basement. That bathroom is below grade so flows into an ejector sump.
Whenever that basement bathroom is used, air occasionally pushes out of the toilet in the new upstairs bathroom pretty violently - shooting water everywhere (of course keeping seat down now!).
So my working assumption is when the ejector pump fires it’s pushing air into the new stack for the new bathroom that then has nowhere to go but out of the new toilet.
Does this sounds reasonable? I’ve attached some picture that shows the ejector line does look to be plumbed directionally correct (flowing right way) - but air could be traveling other direction? Maybe because of the force behind it?
If so, is there a solution that could happen in the basement vs opening up walls in the new bathroom?
I’m thinking add a vent on the horizontal portion of the new stack after the ejector pump that ties back into main stack? Or would a back flow preventer in same place work? Or maybe tie ejector directly into main stack?
In the pictures, the horizontal line that the ejector pump runs into is also the new stack that runs up to new bathroom.
Thanks so much!!!
Thanks so much!!!
