My downstairs bathroom was improperly designed and poorly constructed. The sink and toilet share a vent which is well below the drains. I think I read that the vent should be at least 6 inches above the highest drain it serves. Also the toilet waste pipe runs very noticeable uphill. Needless to say, performance is not good.
So, I need to re-do both drain and vent. Here’s my layout. If you were sitting on the toilet, the sewer line exits the house directly below and behind you. The toilet drain, though uphill, runs between your legs for about six feet, then 90s down for about 2 /12 feet to meet the main sewage line. So, visualizing a flush, the waste goes between your legs, out in front of you for six feet, 90s down to the sewage line, then exits under you into the street.
I want to run a new toilet drain, just like the old one, except slope it down, rather than up. (By the way, what’s that formula to determine the proper slope?). So, where on this six feet run of new pipe would I put the 3’’ vent line? And, how can I tie in the sink vent, or should they be separate vents?
I would like the vent to do this if possible. 45 (or 90) degree off the new drain line, 90 (or 45) degrees up into the garage (about 11 feet up, turn 90 to run 12 feet horizontally across the garage ceiling to the exterior wall. The other alternative is to exit above the garage door, but that would put the vent right outside the bathroom window, which seems not so good in the warmer months. But, this would eliminate the long horizontal run. Thanks.
