Redwood
GAM said:The new toilet is an American Standard. I really don't think a cracked bowl is the problem...
OMG... Say it isn't so! A defective Am. Std. Toilet?
Who Woulda Thunk?
A plumber works a lot better....
Save your money for the fix that works...
How have you decided that you have a blockage?
Every house should have a decent closet auger, especially if you have the first generation 1.6 gallon toilets. I went through several cheap ones before I bit the bullet and bought a Rigid for about $20. The shape of the head makes it easy to go around bends by rotating the handle, and if you dry it off with a paper towel it doesn't drip on my way back to the basement to store it. After 5 years it hasn't rusted too badly either.Thank you for your time! I'm going to try first a blockage removal product for septic tanks. It's cheaper than hiring an plumber with an auger. What do you think?
If the level falls below the trap, then air flows freely from the DWV system into the bowl, without disturbing the water -- it can't be siphoning or vent problems, or other-toilet problems; look at the cross-section of the trap:I pour water in the bowl, and within an hour or so, the level has dropped. The next morning it is lower still by an inch or two. Within days, it is WAY down. The funny thing is, it does not ever appear to drain completely dry. Does anyone have any ideas here?
Don't suppose you've still got the old one, by any chance?I replaced the toilet with a new one, and have the same problem with the new one. I am doubtful both have cracked bowls...
I'm not sure, I haven't tried flushing one toilet while looking at the one in question. I'll try it.
I have begun to notice some minor however evident odor problems in this bathroom
