Hello,
I am a homeowner and have been around toilets for many years. I am not a plumber, but I can replace most of the "guts" in a toilet with big box store components. I have never replaced a toilet and leave that up to the pros.
We had a Kohler Wellworth installed the other day from a master plumber friend. No leaks, no problem. However, I noticed today that once the fill valve stops filling the tank, there is about 8" of water across the surface of the water in the bowl. Looks fine. However, once the fill valve turned off, the surface of the bowl water goes down to about 5" across in about 20 or 30 seconds. This is consistent flush after flush.
I was on the phone with Kohler tech support and verified that the tank water level after filling was OK. They asked me to put a level across the bowl and it turns out the bowl is not level (left to right). Off by about 1/4". They said there was a siphon going on because of this, and leveling out the toilet would fix the problem.
Anyone know if this could be the cause? Is there a way I can test this theory, short of trying to raise the left side of the toilet 1/4"? I'm concerned about the wax ring.
Thanks in advance.
George
Thanks in advance.
George
