Contracheatcode
Need help to ensure proper venting of toilet and shower that share same vent.
See photos below:
Question 1) does this configuration work? Specifically can I wet vent the shower drain via the toilet black water 3 inch pipe?
Question 2) If yes, where would you recommend connecting the shower drain to the toilet drain?
Box 1: which is BEFORE the drain drops about 12 inches and turns 90 degrees?
Box 2: which is AT the drop? I would need a 90 degree street with a horizontal 2 inch inlet for shower drain. Do they even make that?
Box 3: which is right after the drop/ turn? I think can fit the shower drain p-trap and have it smoothly turn down into a wye in box 3 area.
Thanks to all.
Mike
See photos below:
Thanks to all.
Mike
