thatjohn
We're building a new bathroom and installing a 36" x 72" tub in an alcove and are trying to find a cost effective way of pulling ~80 gal. for the tub in a reasonable amount of time, while also being able to divert to a shower head.
The lowest cost thermostatic mixing valve with volume control valve we could find having an acceptable flow rate (around 13 GPM @ 60psi) is the 3/4" American Standard R540. (We are able to pick it up for under $200, trim kits are available for under $130. Other manufacturers, after including the trim kit, seem to be pushing over $600. We understand the R540 has a weak link with some of its plastic parts, so this lower cost option does have some caveats. )
We're trying to decide between a twin ell with diverter spout or a transfer valve to select between shower or tub spout. The twin ell/diverter spout seems the lowest cost and least complicated option, but our plumber says that he hasn't installed a twin ell "since the 80's" (a bit of a hyperbole to be sure) and that transfer valves are far more common today. Problem is, American standard doesn't seem to have a 3/4" transfer valve (so it may reduce the flow rate?) and we're not sure the extra cost is worth it.
What are the downsides of using a twin ell with diverter spout, and do we need to stick with a 3/4" diverter spout in order to keep the 13GPM flow rate?
Also, are there other cost effective thermostatic valve bodies with relatively high flow rates you would recommend over the R540?
