Terry:
A standard TOTO Drake installs at 10-7/8"
Standard meaning 12 inch or 10 inch?
The horn on that bowl is 2-5/8"
I'm not sure how this factors in. Would you be able to elaborate?
By shifting the closet bolts a little bit, it's likely you can set the standard 12" rough without doing anything at the floor except for slightly locating the bolts just a little further out.
It sounds like this advice is predicated on there being enough wiggle room to make a 12 inch toilet fit a 10 3/8 inch rough-in, correct? I'm not sure where this wiggle would come from as there is no gap between the existing tank and the tiled wall.
Or pretty much all brands have 10" options.
One model I was contemplating was the UltraMax II which doesn't seem to have a 10 inch model and is the reason for posting this question.
Most do that by having a smaller tank, TOTO has a 10" bowl, The C744EF.10 and also the Unifit adapter in 10" for their II series bowls.
It looks like the CST744EF.10 is only available for the Eco Drake® Close Coupled Toilet, 1.28GPF, 10" Rough-In (CST744EF(R).10) and Drake® Close Coupled Toilet, 1.6GPF, 10" Rough-In (CST744SF(R).10) which would mean picking based on flush volume. The only other 10 inch models are the
Aquia which is skirted which I have read elsewhere can complicate installation or Aimes which is way expensive.
The American Standard Cadet series has a 10" tank that fits their round, elongated and ADA bowl.
Based on another of your posts (
https://terrylove.com/forums/index.php?threads/kohler-vs-american-standard-toilets.32604) and reviews on other sites AS doesn't fill me with a lot of confidence unless the Cadet series is an exception.
With regards to 10 inch vs 12 inch I am holding out hope that maybe there is still an option for the later. However, I am rather risk adverse when it comes to this kind of stuff. I just want this to go quick and painless and not have to think about it again for a long time.
Thanks for your input.
