To check valve or not to check valve?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by gokorn1, Oct 10, 2018.
  1. gokorn1
    gokorn1 New Member
    Oct 10, 2018
    Alaska
    I'm replacing my well pump and there was not a check valve on pipe from the pump to the pitless. Pipe is approx 20ft long. Well depth is 40ft. I had an issue where the pump was running all the time. When the power was shut off the pressure would drop to 0 instantly. Replaced the pitless adapter oring and pump. However i did not see a check valve, I was wondering if one is required. I'll be finishing the installation tonight after work. The only reason I don't think one is required is I saw a info board at Lowes that said place one every 100ft. I know thats not the best place for information but thats all i can find.
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Most submersible pumps have a built-in check valve, but you can add another right above the pump. Don't put one in up higher.
    You should lightly lube the o-ring with silicone grease.
    gokorn1 likes this.
    gokorn1 likes this.
  4. gokorn1
    gokorn1 New Member
    Oct 10, 2018
    Alaska
    Thank you thats what I was hoping to hear. I've got some good grease from water store.
Similar Threads: check valve
Pumps and Tanks Well Forum & Blog. Water is life. Why should a check valve be at the top of the well near the pump instead.. Dec 18, 2018
Pumps and Tanks Well Forum & Blog. Water is life. How to prime check valve suction side. (no foot valve) Dec 3, 2018
Pumps and Tanks Well Forum & Blog. Water is life. Check valves always fail, must be my setup Nov 12, 2018
Pumps and Tanks Well Forum & Blog. Water is life. Check Valve, Foot Valve or Both Oct 5, 2018
Pumps and Tanks Well Forum & Blog. Water is life. Multiple check valves on sump pump Sep 28, 2018
