TK-510U-I Venting Question
Joseph Skoler
Sullivan County, NY
Can someone please let me know which sidewall termination pieces I need for a Takagi TK-510U-I?
The exterior wall that it mounted to (on the inside) is a wood frame (sheetrock inside, fiberglass insulation between studs, vinyl siding exterior) wall.
This is a non-condensing unit, so my understanding is that I do not need a condensate port, drain, pump or neutralizer.
I have read the literature, and there are combustible sidewall pieces and non-combustible, but then the part numbers are all changed and discontinued and I can't find the right pieces.
Is there a concentric (single pipe) solution for intake and exhaust?
Thank you!
Depending on whether you are direct vent or pulling combustion air from the room, I would use the appropriate combustible termination kit.
