I have almost always used brass when possible but have found most of my plumbing supply stores don’t keep it anymore. If they do it is the cheap stuff out of China and doesn’t seat well. With that I have started to use more Stainless steel fittings and am ending up with leaks. I generally use tape and dope but sometimes just dope. Had a corner and ended up with multiple leaks, took it apart and tightened the corner and still had leaks. I couldn’t tighten the silly thing any more the third go around so I found a way to do the corner in PEX (takes up a bunch more room) but didn’t leak. I have also had problems with SS unions.
