James23912
Hi I am about to start installing a used pedestal sink, I know the basics of a sink install but don't know the specifics of what order to do this thing.
one technical need is what to use to transition from the tee that is inside the wall to the metal drain.
other than that I am trying to figure an approach, I assume attach the faucet and water lines before installing the 2 pieces and then trying to connect everything after? Or is it possible to set the sink top up with temporary supports a bit higher than it will end up and connecting everything and then squeezing the pedestal under it?
the tee in the wall is 18" off the floor , the 2 water lines are 24" up and 4.5" apart, I did not do that part.
the pedestal itself is 27" high , 7" wide, and the bottom of the sink hole will be about 26" off the floor and 7" to the center from the wall, any tips appreciated, thanks
