Mculik5
I'm in the process of installing a Kohler skirted toilet. It's brand new. After installing and leveling the toilet, I turned the water on. Immediately, there was a pretty fast drip from around the nut that holds the valve assembly in the toilet.
Long story short, I tried a bunch of messing around and ultimately decided it was something going on with the valve nut and/or washer, so bought a replacement.
Uninstalled the toilet and removed the old (but brand new...) valve. I figured I should check for any kind of debris in the tank that might be interfering with the washer and noticed a tiny crack in the tank. You can see it in the attached picture.
It's about 3/16" long and does not go all the way through, but it's providing a path for the water to get below the washer, hence the leak.
What should I do:
- Try to replace it, either through the plumbing supply house or Kohler directly?
- Put a washer on the backside, between the tank bottom and the valve nut, and call it a day?
- Caulk the crack?
- Both the washer and the caulk?
My gut says replace it, but that's a bunch of logistical work. If this is something that's relatively common, and the washer/caulk route will work perfectly fine for the life of the toilet, I don't want to make a extra work for myself.
Thoughts? Thanks.
What should I do:
- Caulk the crack?
Thoughts? Thanks.
