mcgeggy
I have an old Rainsoft Apollo that is no longer draining the water out of the salt hopper. I can't find anything wrong with the hoses and air check valve. Water does drain out the drain hose from somewhere - but the water does not drain out of the salt area.
This system operates on a timer. I think a system that operates on a meter would be best to go with now. So....
Can I just add a new valve assembly to the existing unit that is metered, or is it not worth it? (Resin too old)?
How should I go about figuring out what to replace the Rainsoft with? All I seem to read is how awful Rainsoft is (high pressure sales, expensive, etc). Can I buy a new system and would a plumber come in and hook it up, or is this not the type of thing they generally do?
I don't want to get ripped off, and I want to get something that is low maintenance and reliable.
I also have a another tank with calcite to raise pH, which I replaced myself 10 years ago (new tank & media, new Fleck 5600 valve). The space I have where the softener is is pretty tight - so I'd like a whole new setup to be right around the same footprint as the Apollo system that I have now (hopper with resin tank in hopper).
I have not gotten my water tested yet. Well and septic, family of 4 in a single family 2 bathroom house.
Thanks for ANY advice you can give!!
