Ken Tannenbaum1
I need to put a T into a 3/4 copper line with little room. I figure to use a Sharkbite Slip-T. I should be able to cut the pipe with a Rigid cutter but don't see how to deburr the pipe with so little room. Not even sure I can fit the Slip T into the pipe length I plan to remove. Probably need to break out much more wall to relieve the pipe from the framing...just don't know yet. I'm a home owner brave enough to do all the trades work but never used push-to-connect so want to do it right. If the cut pipe is clean, does it NEED to be deburred too? Thanks very much.
