DW85745
I'm getting tired of emptying the bucket under the A/C Drain line. Since the 3 inch line to the septic system is close by I'd thought I'd tie in the drain line with a rubber coupling, so if needed, I can clean the A/C drain line.
I don't relish digging up the 3 inch line to try and get enought play so wanted to find out if:
1) They make a saddle for a 3 inch ABS line?
2) What is the smallest pipe I can get coming off the saddle?
3) Any chance they make a outside/inside rubber sleeve such that I can push it inside of a "1-1/2" or "2" ABS and then pusn in the "3/4" A/C drain into the inside of the sleeve. I know they make these for larger holes "4" ++ as used one when I recored a septic tank, but don't know about smaller.
4) Any better suggestions appreciated.
