Kyle Altendorf
Other project threads:
While I've got access to my subfloor to build it up for tile, I am curious if I should be anchoring my supply lines to the floor. I have one toilet supply coming through the floor and two pairs of sink lines that will be inside a double vanity. I have seen references to people grouting directly against the supply lines which wouldn't work terribly well with a loose pipe but I could easily imagine that pipes should have some play to avoid undue stress as they (and the rest of the house) grow and shrink a bit with temperature and humidity. So, anchor supply lines at the floor or not? If yes, what is used for this?
Also, I am interested in using a Kingston Brass C43158X cross handle stop valve in nickel. For all the time I am (inefficiently) putting into this bathroom (I'm learning, that's it) I think it will make for a nice detail with the faucets my wife has picked out. That said, it only seems to be available in 1/2" IPS input, not the 3/8" that is presently there. It's not a big deal to cut out and replace a small piece of the decking to sweat on a 1/2" fitting but before I do that, am I correct in my impression that 1/2" is the standard for toilet supplies now? I feel like 1/2" has been more common as I've looked around. I'm not too worried about the sink supplies since they are already plumbed well above the floor and are hidden anyways.
Thanks for your continued help here and have a great day.
Cheers,
-kyle
Cheers,
-kyle
