Suma87
Problem:
Changed light bulbs from incandescent to LED and LED bulbs do not shut off even when switch (leviton mural) is off. Found out switch doesn't support LED. Have the leviton mural switch on first floor and MS00R-1 remote on second floor. Removed switch on second floor and tried to install leviton IPL06 switch on first floor but still doesn't work.
First floor: all three wires are hot except green
Second floor: red and black are hot.. Black (with white coating) and green are not hot
I had spent half a day and trying different wirings and still couldn't understand how the wiring works. Please help and would appreciate any suggestions. What is white/gray wire does? Doesn't seem to be a neutral line?? This is the most complex wiring I'd ever came across
Leviton mural switch installation instruction:
http://www.leviton.com/OA_HTML/ibcG...p8LA1stQ&label=IBE&appName=IBE&minisite=10251
Leviton IPL06 instructions
http://www.leviton.com/OA_HTML/ibcG...hLzCk0-A&label=IBE&appName=IBE&minisite=10251
First floor:
After removing switch
Second floor (original wiring)
First floor:
