Dan WZ
Hello,
I am remodeling a bathroom and I have 3” PVC for the toilets and main line. It runs across under the joists and the toilets etc. run with or in between the joists. My line ends with a toilet that drops into a 90 and has a 3x3x1.5 next in line to catch a sink. I need to add the toilet to the end of the line. I can do this with two long 90’s but it will be tight.
If you look at the picture the new toilet will be coming out from the left side directly opposite the current end toilet. I only have one 16” joist cavity to work with.
My question is - is it ok by code and should I use a 3” three way 45 degree horizontally?https://www.homedepot.com/p/NIBCO-3-in-PVC-DWV-45-Degree-H-x-H-x-H-Double-Wye-C48343/205799566
Thanks
Thanks
