Jimjr
Hello,
I have three questions and a picture for each of them.
(1) Is it safe and effective to "seal" off septic tank gases by using a Fernco rubber cap? Or, should you glue on a cap?
(2) Is the way I did the plumbing coming directly out of the toilet flange OK or will it cause you to often use a plunger?
(3) Is the "drop" in the toilet waste pipe too abrupt? The "drop" is two consecutive 45s. Will this "drop" cause drainage issues?
Thank you.
Thank you.
