Tacmatt
Hello, I have a question I'm hoping 'those who know more than I' can answer.
First, new user, new homeowner, limited diy skills but eager to learn and do... I've never posted on any forum so please be helpful if I screw up. Any guidance is appreciated. Now my issue...
I was looking for water shut off in crawl space so I could turn off water to fix a dripping bathtub faucet when I noticed a leak coming from bathtub drain pipe. I'm pretty sure the metal drain that connects to ABS is brass (non magnetic, 1 1/2in, doesn't shine like a penny when scratched). The brass pipe is threaded. The leak, and I will confirm this before diving too far in, seems to be coming from the no hub coupling that connects the metal pipe to ABS. The coupling in the picture was found nearby in crawl space and is similar to the one attached. The one attached feels (and looks) deformed, as though the band on the brass side slipped off pipe (smaller diameter than original). I hope this is all making sense. My plan is to remove ABS wye section, rebuild and reinstall. My main question is what is the best way to make the connection between threaded brass pipe and ABS? I wonder if the coupling used is wrong. Also, not entirely sure there is a p trap but there is water in the drain, no smell, etc.
I'll post photos later, time to go to work.... Thank you all
