Thread locker on pipe unions
Discussion in 'HVAC Heating & Cooling' started by Alessandro Bortoloni, Mar 18, 2020.
  1. Alessandro Bortoloni
    Alessandro Bortoloni New Member
    Mar 18, 2020
    Syracuse NY
    Hello, I am having issues keeping pipe unions tight. The company i work for makes industrial sized gas dryers. We use a 2" pipe union on each end of our gas train. We build the machines, ship them out cross country to customer sites, and by the time my technicians arrive, the unions are all loose. Is there a sealer or a type of loctite that I can use on the union threads to keep it from coming loose?
  2. Sylvan
    Sylvan Still learning
    Sep 23, 2004
    plumbing - fire suppression - boiler inspector
    New York
    If the unions are made up properly there is no valid reason for them to become loose
    MASTERPLUMB777 likes this.
  4. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    MASTERPLUMB777 and Sylvan like this.
  5. jadnashua
    I think you may need bigger wrenches.
  6. fitter30
    fitter30 Member
    Feb 2, 2020
    Retired service tech
    Peace valley missouri
    Tighten as usual then hit it on a flat of the nut with a 2 lb hammer retighten. It won't come loose. When your 5' 6" 160 sometime you need some tricks.
  7. Sylvan
    Sep 23, 2004
    New York
    I really do not having my wrenches hit with a hammer
    This is why I have wrenches 6" - 48" or Chain Tongs and can easily add a pipe on the handle for more leverage when making up 6" threaded pipe
    When loosing an old union I use a ball peen hammer and cold chisel as I replace lots of expansion compensators (expansion joints)
  8. WorthFlorida
    WorthFlorida The wife is still training me.
    Oct 28, 2009
    Retired
    Orlando, Florida
    Are these unions installed at the factory with the machines for the gas connections? What part of the union has worked loose? Is this something new? Has the supplier of the union been changed or another manufacture? Are all fittings NPT?
    Assuming the union is becoming loose at the pipe joint, not the union joint. When the union is placed on the pipe stub, the thread (NPT) may be cut wrong (too narrow and not tapered). Or the union is tapped too wide. The pipe thread is tapered so as you tight the union, the pipe is squeezed into the union and it should be extremely hard to bottom out the pipe inside the union. Or during assembly of the union on the machine, it is being over torqued and distorting the tapered connection.
    If it is loosening at the union fitting, it is not being tighten enough or the unions are not manufactured to spec.
    Google "npt union connection"
    NPT stands for National Pipe Tapered thread. It is also sometimes called National Pipe Thread, NPTF (F for Fuel), American Standard Taper, or simply "pipe". Most other plumbing fittings have straight or parallel threads, but NPT fittings have a tapered thread profile. Sep 11, 2012
    Both NPT and NPS have the same thread angle, shape, and pitch (threads per inch). However, NPT threads are tapered and NPS threads are straight (parallel). ... Straight Pipe Threads need a gasket or O-ring to create a seal. While NPT and NPS threads will engage, they do not seal properly with each other. Feb 4, 2020
  9. fitter30
    fitter30 Member
    Feb 2, 2020
    Have you changed how the gas train is supported for shipping, using a different brand - quality.
  10. Sylvan
    Sep 23, 2004
    New York
    I use Ward black unions or Anvil and never had a failure both are domestic
  11. fitter30
    fitter30 Member
    Feb 2, 2020
    Need to read my post again i didn't hit the wrench i hit the flat of the nut. When your in a pipe chase like your pics hammer and chisel is the only way without opening up the wall more. Any screwed thread bigger than 4" calls for a torch, stick welder and slip on flange. Never used or seen a machine that did larger than 4" .
  12. Sylvan
    Sep 23, 2004
    New York
    IF you need to thread larger pipe
    Do like I do and use a Rigid 161 4" - 6" ONE person can thread it using a Rigid 700 with the adapter for the 141 and 161 stock and you need a vise and oiler
    The 700 is also great for threading pipe in place just hold back
  13. Sylvan
    Sep 23, 2004
    New York
    The above picture is before and this is after one man with a sawzall that cut the nut and then the rest of the union out saving the existing took about 11/2 hrs start to finish
    Materials needed sawzall blade, 2 black nipples , 1 expansion compensator 1 Ward Union (rated) and try not to laugh when handing them a bill for $3,967
    Most plumbers fear trying save the 43 year old black piping on a heating and cooling system . I Figured it is not my home or piping just try my best
    https://www.nyrpcorp.com/keflex/
  14. fitter30
    fitter30 Member
    Feb 2, 2020
    I carried a 700 & 300 on my truck for up to 2" . Phone call can have a 2" -4" machine. Never
    Sylvan likes this.
  15. Sylvan
    Sep 23, 2004
    New York
    For low pressure steam lines and older (before Victaulic) stand pipes it was all threaded , Ever see 7" black steel
  16. fitter30
    fitter30 Member
    Feb 2, 2020
    Yes and 5" ,left threading couplings and 90s. All long gone.
Similar Threads: Thread locker
HVAC Heating & Cooling Another adding the C wire thread (to WiFi thermostat) Jul 6, 2016
HVAC Heating & Cooling Another "Is this reasonable" Quote thread! May 7, 2008
