CK36
I'm remodeling bathrooms in a home in Washington state. The code restricts the flow rate for shower heads to 1.8GPM, but I can't find anything that specifies a max flow rate for the mixing valve (I'm using a thermostatic). Can I install a 2.5GPM mix valve if the code only specifies the shower head must be 1.8GPM?
I did find a proposed code change to reduce mixing valves to 1.8 GPM because the anti-scald function doesn't operate properly with a shower head that has lower flow than the mixing valve, but I can't find anything else on this.
