weightoomuch
I could not plan out my pipe so that I had: less than 24" of vertical fall from fixtures to p-traps, and between 1/8" and 1/2" fall per foot on my main dwv pipe. Does this image look like an acceptable solution? https://i.imgur.com/kI8Iwxh.jpg What are your opinions? Have any advice regarding slope on the elevation change, more or less slope is better?
All of the changes in direction on the main dwv pipe are visible in this photo: 45, 22.5, 45, 22.5 for 135 degrees total. At this location I can't roll the wye and 45 to meet each other without the 22.5 fitting in the middle because there is a support pillar and concrete pad in the way.
If you are wondering, upstream is a bathroom horizontal wet vent. The thing you can see is a floor drain with an individual vent. The reducing wye is rolled way up to keep the fall from the drain to the trap under 24", and it is vented with a 2" wye because I had one.
Thanks, tell me if this all looks horrible!
