Temperature fluctuations shower
2002sheds
Santa Rosa
Hi All,
I’m a bit stumped by this one… we have a second “cottage” on our property that is heated via a Noritz tankless heater. The shower is the furthest away from the water heater, and the bathroom sink just before the shower (and on the same plumbing) is showing no issues with temperature fluctuations.
The “cottage” is downhill of our house (on the same water supply) and there has been an issue with grit in the fixtures. I clean the shower head about twice a year and have removed the screen/aerator from the two sinks — kitchen and bath. I also installed a fine mesh filter where the water comes into the building, but there may be plenty of grit already in the plumbing already…
I will pull the shower head again to make sure there is no change without the shower head, but in the meantime I am wondering if the fairly new (and somewhat infrequently used) Moen single handle mixing valve could accumulate grit, or if that is unlikely…
As always, any and all help will be appreciated!
Thanks,
David
John Gayewski
Iowa
Hi All,
Thanks,
David
Yes if the cartridge has grit in it that will cause temp fluctuations.
2002sheds
Santa Rosa
Maybe this solved…? I pulled the shower head and cleaned a small amount of grit and hard water deposits from the rubber “nipples”. Seems to not fluctuate anymore…
David
John Gayewski
Iowa
Hi John,
Thanks! I’m sorry I missed your reply the other day.
I will search the internet for the way to disassemble the valve and check the cartridge.
Thanks Again,
David
Depending on the cartridge you might have to replace it. If the balancing spool has junk in it, it may never function right again. Then again its worth trying to clean.
You might think about a sediment filter strategically placed if sediment is an ongoing problem.
2002sheds
Santa Rosa
Hi John,
Thanks very much! With the time spent pulling the cartridge, it may be best for me to assume that I will need to replace it.
And I have a fine mesh filter that I installed where the water comes into the building, but I think a filter that is more specific to this line is a great idea.
Thanks,
David
