Hi,
We've got a 50 gallon gas HWH that was installed in 2005 (State is the manufacturer, model PR6 50 X0DS - see http://www.statewaterheaters.com/lit/partslist/res-gas/185507-000.pdf for details). We've never had any issues with this HWH, but last week I noticed two changes that occurred during a short period of time:
1. Temperature drop - I noticed the hot water dropped in temp (noticeable all over - from the bathroom shower, kitchen sink, etc.). It didn't get cold, but it went from "hot" to "somewhere between lukewarm and hot". I checked the pilot on the HWH and it's lit, I turned the temp up and the burner fired nicely. I turned the temp up a few ticks (from the little triangle setting to the "A" setting) and that solved the problem. We've had it set at the triangle setting for years and that temp has been fine for us.
2. A few days after issue #1 above occurred, we noticed a drop in water pressure in our shower. Again, it wasn't catastrophic and a visitor who didn't use the shower every day probably wouldn't have noticed. But my wife and I definitely did.
FWIW, it's possible that the temp drop and water pressure drop happened simultaneously and I was sufficiently distracted by the temp change to not notice the pressure change until a few days later...
We're located in the PNW and have lovely city water (not hard, not soft - awesome for drinking straight from the tap), so we don't usually have issues with mineral buildup in pipes. Our pipes were all re-done about 12 years ago and are a mix of copper and PEX.
Any thoughts on what could cause these two issues to occur at around the same time? My current theory is that there's some kind of buildup in the pipes from the HWH to the supply lines that's blocking the HW delivery, this decreasing the pressure and letting in less hot water. But I thought I'd check with the experts here to see if any of you associate these two issues with any other common problems.
Thanks for any thoughts!
