Teflon tape
KD
How many layers of teflon tape should you apply? I have been doing 4 layers. Also, I have seen plumbers use tape and teflon pipe dope on the same connection is this a good idea??
GrumpyPlumber
Licensed Grump
Licensed Grump
4 is good.
The right way on threaded water connections is dope, teflon, dope.
Jimbo
San Diego, CA
Many of the best plumbers on this form swear by various combinations of dope and tape. Personally, I use one or the other and honestly do not have issues with leaks, but I never argue with what works for someone else.
With the very thin white tape, 3 to 4 wraps is probably good. I mostly use the much heavier yellow tape for everything, gas and water, and 2 wraps of that is fine.
Patrick88
Webster Ma.
3-4 wraps is good and some pipe dope is also good for water lines. you don't need both one or the other is also fine.
Tape on gas lines:eek: I think you just gave a Ma. inspector a heart attack. Pipe dope is the only thing to put on gas lines. Nothing more nothing less.
GrumpyPlumber
Licensed Grump
Licensed Grump
Patrick, we adopted the nat'l fuel and gas code a few years back.
Yup, in theory we can use tape on gas.
I see it more and more on service calls for newer boilers & heaters.
Patrick88
Webster Ma.
I stand corrected my bad.
I guess i do things old school. I have questioned it about a month ago on a warranty swap out water heater that was about 6 months old. The gas lines were taped and my boss said guess they did not bother getting it inspected. taking the tape off was a real pain too.:(
Guess i will need to kick my boss:rolleyes:
Cass
I will inspect the threads on the nipple I am taping. The junk that is being imported sometimes has deeper than normal threads. I will use 5-6 wraps on those.
I had some recently that I had to toss because the threads were so deep that they never tightened up.
Spaceman Spiff
Architect
Salt Lake City, Utah
Want a super fast way to take tape off?? (I learned this from a hydraulic maintenance guy) Just blow compressed air across the threads (perpendicular to the pipe) and in a split second all the teflon is five feet away... Even works on threads with oil or whatever on it.
