Finishing my basement. We are under the 2015 UPC. I will have a bathroom with shower, vanity, and WC. Bar area will have a bar sink and a dishwasher. All will be used intermittently. My existing copper manifold hot and cold sides only have one 3/4" connection each and that supplies the master bath so if I used the 3/4" to supply the new fixtures I would have to tee off the existing lines. I have an unused 1/2" connection in the existing manifold for both hot and cold.
Each fixture will have it's own homerun back to new 6 port copper tees/manifolds which will be located by the main manifold. The new tee takes a 3/4" sweat connection so I could use a 3/4" or 1/2" fitting. The bathroom runs would be about 70 feet, the bar is about 15 feet. Our water pressure is around 45-50 psi. Looking at the UPC tables, I would have 4.5 fixture units for hot and 5.5 for cold so 1/2" appears to work for all the branch runs.
To meet code and get decent performance should I tee off the exiting 3/4" lines for the new tee/manifolds or use the open 1/2" connections?
Thanks in advance for your help.
