Brad Littlejohn
My tankless (outdoor/Natural gas) has a manifold layout out for cold and hot. Every fixture is single-homed from a manifold in the center of the crawl space. I am planning to leave the cold water manifold alone if possible.
Should I:
- Put all the hot water connections on one big loop throughout the first and second floor with 1/2" branches off the loop a few feet from each fixture? I know that 3/4" in the min for the trunk. But, would 1" be better? I want to prevent noticeable pressure drop when several fixtures are being used at the same time.
- Create a parallel manifold system for the hot water that would connect to the existing hot water line at each fixture. I would think that physics would come into play here and hot water recirculation would take the least path of resistance. The first fixture in the loop.
-Install a hot water bypass valve at each fixture to the cold water line . Once the closest bypass valve gets up to 120 degrees it will close. the next least path of resistance would be the second fixture. Then after a couple of mins, all bypass valves would be at 120 degrees blocking recirculation. Then bypass valves would randomly open and close as they cooled off.
- One bypass valve from the furthest fixture.
I have a 2250 sq ft house with two floors. 6 hot water connections on the second floor and 4 hot water connections on the first floor.
I have been trying to find an article on the best option. But, no luck.
Should I:
