Tank to bowl rubber spacers/bushings/shims - where to buy?
Frankpc
Kansas, USA
Toilet had three(?) rubber spacers (bushings or shims?) between the bowl and the tank. There are two along the front edge of the tank and maybe just one on the back edge in the middle. The two spacers on the front edge are still there. But the one (or two) along the back edge have broken and fallen out.
I've searched for replacements but cannot find any. Does anyone know where they might be sold?
They are rubber and about an inch or so long. About 1/4" thick but they are contoured to stay in place along the front and rear edges of the tank. Brand of toilet seems to be 'Vitra' and is probably 12 or 15 years old.
Tank wobbles now and the tank to bowl screws are loose without the rear spacer(s). No leaks yet.
Thank you.
Frankpc
Kansas, USA
Is this a Kohler toilet?
I believe it is a "VitrA"
I attached three photos. One showing the brand name and two showing the rubber shims.
Thank you for the help! I've searched everywhere I know to search for these rubber supports
John Gayewski
Iowa
Gerber comes with at least one rubber support. I think Kohler has them integrated into thr tank to bowl gasket. That's why I asked.
Otherwise I think anything similar cut to size would work for you.
Frankpc
Kansas, USA
OK. Thanks. Per your comment, I did a search on Gerber parts and I found some similar shims in a repair kit, I've attached the photo. I have some rubber toilet leveling wedges that I bought before realizing they were rubber. Maybe they will work for the shims.
Thank you for your time!!
