thepipe
Hello, All:
HELP! After only 9 years of use, my T-K1S began leaking inside today. I tried to figure out where it was coming from, but can only determine its general location: below the copper heat exchanger. In addition to the leak itself, I think the water shorted something out because it won't respond to demands for water. The unit does have power, the 3A fuse is good, and the GFCI is operating properly. My TK-RE02 remote indicates error 74, which is remote error. When I remove the remote from the circuit there is no change to the operation of the unit.
Is this worth fixing? If replacement is better, which brand and model should I consider? I'm not in love with Takagi, but would be open to a similar unit from them (or anybody) which would just "bolt in" to the old location. The T-K1S BTU output, 190k, has been perfect for us. I don't need the added expense of the PVC-venting units and despise the thought of discarding that expensive stainless vent pipe already there. I must decide soon since we have zero hot water.
Any thoughts?
Any thoughts?
