tropostudio
I've installed a Westinghouse WBRUNG080 modcon system, using Uponor manifolds and Myson T6 radiators. It is pretty much a home-run system, with each emitter having its own TRV, except for a couple locations where I installed a pair of emitters in series, using a Myson bypass valve at both units in the pair.
The sketch labeled 'Current Emitter Piping' shows how it's set up now. The sketch explains issues with the system, and need to have a minimum 1 gpm for the boiler even if all loops closed down. Sketch labeled 'Modify Emitter Piping System?' shows my thinking to help make system easier to balance, and to simplify adjustment of a 1 gpm flow to boiler if all loops were closed. I welcome any critique, or suggestions for other options.
FWIW, there are actually 3 manifolds, each with 5 loops, to cover a 3 level house. The other 2 manifold are in parallel with the example shown in the sketches. CH is operated off one Grundfos Alpha pump. No primary-secondary. I currently have that running in constant pressure mode on low, which gives 1 gpm. Running it in AutoAdapt brought the flows below 1 gpm. DHW is provided via na Amtrol tank with Grundfos 3-speed circulation pump, set on medium speed (did the head loss calcs to pick that speed). Call for heat is insured by a single Tstat wired to boiler, set at a temp higher than all TRV's. Outdoor re-set is used, although it's not optimized yet.
