Kihong Lee
Hello.
I have a flapperless toilet and inside of the toilet tank, there is a some kind of bucket in it as you can see the first attached picture. So I just decided to take it out and to replace it to normal flush valve with flapper.
But after I took it out, as you can see the second picture, realized the toilet bowl hole for flapper is something different. It is not circle-shaped. So I just couldn't install normal flush valve with flapper there because normal flapper is circle-shaped. Also, the hole which connected to the toilet tank flapper hole is, of course, is same shape, as you can see the picture.
So if I want normal flash valve with flapper, should I change whole toilet tank/bowl? Or there is flush valve with flapper which fits this kind of toilet tank?
Thanks,
Thanks,
