Hi all, new to this forum.
I am planning to replace an existing double sink with a new deeper double one.
I currently have the garbage disposal running over to the second drain and then to the P trap.
There is also an open pipe with a trap running under my counter top that has the dishwasher drain run into it, that drain is lower then the sink drain.
Since I only have one drain pipe coming down into the basement, I assume these 2 are running into a single pipe behind the wall.
With the new deeper sink can I swap the dishwasher drain with the sink drain, since the dishwasher drain is lower?
If yes, suggestions on how to connect the new sink drain since I will have to cut the existing elbow at the back of the cabinet to install the new cabinet?
I would then reinstall the elbow trap on the upper connection for the dishwasher drain. Does that one need to be glued vs. screwed?
Thanks in advance for your response.
Dan
Dan
