Waterboy Juan
I've just noticed that my pressure tank is cycling on and off every 3 minutes. I can hear it clicking. My pressure gauge is stuck at 48psi, likely due to sediment, and I'll fix that in a couple days. I closed the line immediately after the tank to ensure no house leaks or consumption, and the 3 minute cycles continue.
I put a pressure gauge on the valve at the top of me Well-Xtrol 42 gallon, 40/60 tank and watched it throughout the cycles. It cut on when the bladder pressure was 38, psi as expected, and cut off 45 seconds later at 58 psi. During the next 2+ minutes, the pressure drops, then the cycle repeats.
I have a Red Jacket submersible that's probably 10 years old.
I'm a well newbie but suspect a faulty check valve from what I've read. What do y'all think?
