Hello,
Finishing my basement and relocating the washer and electric dryer against an unfinished exterior basement wall (don't worry, it's sufficiently below grade to be safe from freezing). Electrical to both washer and electric dryer are routed through ceiling joists to this location, and then I plan to drop down from the ceiling, along the facade of this exterior wall, to outlets for each of these appliances. I'm using Armored Cable for all electrical (i.e. "MC Lite"). I am not using NM cable.
What does the NEC say about running AC, exposed, (i.e. mounted on the surface) along a wall?
Should I transition to EMT? If I need to transition, I've read that the transition fitting needs to be accessible. Is this true?
If I need to transition, I've seen transitions done in a 90deg bend fitting, but is this the only type of transition fitting available?
All advice and guidance greatly appreciated.
Many thanks.
Theodore
Many thanks.
Theodore
