Background: house built in 1986, well water, pressure tank. I do all the plumbing, but we only bought the house a couple years ago, so problems may or may not be my fault
Water pressure in our sinks is normally really good. It's great in the showers.
But when the washing machine is filling, the pressure in the sinks drops way down. If someone flushes a toilet at the same time, the sink pressure is literally just a trickle of individual drops.
Of course the sinks have aerators, whereas the toilets & washer do not, which partially explains the pressure differential -- but still, I don't think the sink flows should drop so ridiculously low like this.
I've tried partially closing the valve that feeds the washer, and also tried an inline pressure regulator (the kind for RVs), but neither solved the problem. Both just make the washer fill really slowly -- the pressure in the sinks is still crap.
I even bumped up my well switch settings up from 40-60psi to ~50-75psi (cut in-cut out) -- no improvement. It seems any extra pressure is immediately stolen by the washer/toilets.
What else can I try?
Thanks,
Anthony
Thanks,
Anthony
