rick52768
Evening All, I am helping a friend that has a sump pump that is no longer pumping. It works great as a heater, keeping the sump basin water temp around 120 degrees. It hums, the float stays engaged. Simple enough, it needs to be replaced.
My questions revolve around two areas which I have no experience. The sump basin looks to have a crack in the side. The basin is located in a unfinished walkout basement. The main purpose of the sump was in case a small creek about 250-300 feet from the house floods. The builder also plumbed the HVAC condensation and water heater pressure relief valve drain lines to the sump.
Is this crack something to worry about as it is not a pit basement, the yard runs away the house and drainage is good?
Next, the check valve and couplers are PVC that the plumber put plumbers joint compound in the threads. Even on metal to metal joints I sometimes find it very hard to break the joint loose. On this 2 1/2" (from memory) PVC joint, it is not budging at all. I have a good size set of channel locks that did not help.
How can I soften the plumber joint compound without damaging the joints?
Thanks
Thanks
