Sump Pump Noise Transfer to Bedroom
I just had a plumber install my new Zoeller 57 Series sump pump. It was installed correctly with a check valve and union above the sump pit. The piping runs up to near the floor joists in the basement and then angles to the left and out through the foundation wall. The piping is PVC and is suspended with plastic pipe hangers from the floor joists. This is just below a bedroom where I sleep. My problem is that the piping transfers a lot of noise, vibration and pumping sounds as well as the "thunk" of the check valve through the joists and floor. The level of noise is enough to wake a sleeper. Is there a different way to route the piping, insulated the pipe hangers from the joist etc. to lessen or eliminate the humming, gurgling and other drainage noise away from the bedroom upstairs? I cannot move the sump so I am stuck with this problem until there is a solution. Would insulation between the joists dampen the sound somewhat?
Any answers would be appreciated.
Thanks, jmgmcg
Thanks, jmgmcg
