Robert Mazzaferro
Hello: I just joined the forum and need a little advice on replacing a high-volume Sump Pump and installing a separate pit switch. I hope I am placing the question in the correct area.
My situation, I have to replace my sump pump it is time. I have had this pump which is a Rigid 1HP with an electronic switch that they do not offer any longer. I have had great service with it. I also have a backup natural gas generator, when I lose electricity that turns on automatically.
The house when I purchased it came with this system called B-Dry. Which they install 4” or 6” piping along the bottom of the foundation where the water flows into the pit (18X22) and is pumped out away from the building. This system has worked well and it has only flooded once in over 25 years I have been here due to no electricity. (just want to give all the conditions I’m dealing with).
The original system pump was a Zoller which worked for more than 20 years and when that needed replacing, I have used the Rigid 1HP pumps which had worked. The pump has a 1.5 discharge into a 2” pvc piping system which also has a 10-foot vertical lift using a 90-degree angle, with check valve with no pressure 3/16 relief hole in the pvc & there is 20 feet of piping with 12” of slope, so once the water is pump to the 90 angle it is gravity fed away from the building. Over the years we have been getting more water as it seems the water table has increased.
In the heavy season of water (spring) the pump cycles every 20 seconds which I am estimating that with the type of pump that I have and the size of the pit it pumps approximately 60 gals per minute, as there is about 2” of water at the bottom of the pit and the pump is 12” high therefore 10 inches (approximately 10 gals) of water every 20 seconds. (please correct me if I am not accurate). I understand I need to decrease the cycling of the pump after reading info from this forum. The water it is clear as well.
I am looking for the most secure system that I can adapt to my needs. Which would be to decreasing the pump cycling. I am thinking replacing the pump with a high enough volume, cast iron immersible Zoeller with no switch on the pump and installing separate switch like a Vertical Master switch therefore decreasing the pump activation.
Any suggestions are truly appreciated, rely here or email rmazzaferro@hvc.rr.com.
