Keith Blanchard
I have a 4 inch well that has been having issues since i purchased the house 2 years ago.I had the water tested and the iron content was off the chart but everything else was fine.(no bacteria etc)
Last week the pump finally gave out and i had to explore my choices.
I did the usual above ground check like replacing pressure switch checking air in storage tank and verifying i had power.
I decided to pull the pump and found it was piped with 1 inch sch 80 pvc. This PVC was in 20 foot sticks that were threaded on the ends and connected using galvanized couplings.
I pulled about 50ft of pipe and could feel the pump getting stuck in the casing(it is a black iron casing).
tried several attempts but could not get pump past this point.
So i jammed pump just enough to un- thread the rest of the pipe and knocked the pump back down the well.
Pulled about another 50ft of pipe.My guess is the casing busted at about 50 ft and that is why after a heavy rain my filters clog and look like i rolled them in mud.
I looked into a 3 inch deep well pump and they run about $800 but i am not sure this will make it past the bad spot in the casing. Also bought a jet pump but the cast iron Y would not fit in the rusted well.
Currently i am using a 275 gallon IBC tank and just pumping water with a transfer pump into the house.
This is working fine i just need to be able to get water from well to IBC tank.(see picture)
My Plan now is to just pipe a 3/4 inch PVC with foot valve and use the transfer pump to fill up IBC tank when i need it.
This should be OK until i can get the $5000 to drill a new well.
TLDR;
4 inch well drilled in 60's or 70's with black iron 4 inch casing seems to have collapsed.
What would be best way to get water to IBC storage tank from well?
Any suggestions For a fix would be greatly appreciated
****NOTE I do not need a lot of pressure or flow i can fill up IBC tank slowly
TLDR;
