Liam DuBoise
Describe the well casing. Diameter? Depth if you know?
Look down the hole. In the day, direct the sun's light down the well with a mirror. At night, shine a bright light down. Do you see a restriction of some sort? It might be that could be cleaned off.
You should not put a full size 3.9 inch "4 inch" pump down steel casing. There are slimline/trimline 4 inch pumps that are a tad smaller. I have a trimline pump down my 4 inch steel casing. I think I would go to a 3-inch (SQ) pump if I get my pump replaced.
Depending on the restriction, a 3 inch pump may be worth considering despite having bought a new 4 inch pump.
The casing is 4" steel, with some surface corrosion inside and outside. Depth to the water is about 35'. Depth to the bottom is 65'. The old pump was set at 63'. I'm in Florida, so no pitless adapter. There is a dark patch on the inside of the casing at about the depth where it snagged, but I don't really see anything else. When I pulled the old pump out it snagged slightly at about the same spot.
